1. t_kopta's Avatar
    Any way to get new fonts for free? ones for the entire os not just a launcher....?
    05-05-2012 05:39 PM
  2. piizzadude's Avatar
    yeah you can find them in the market, then change it in settings--> display.
    THis is the program i used on my Charge: https://play.google.com/store/apps/d...G9taXplclNQIl0.
    t_kopta likes this.
    05-05-2012 05:42 PM
  3. t_kopta's Avatar
    You know I downloaded this before and, being a guy, I was impatient and didn't read the instructions....I love it, thanks agian!!!
    05-05-2012 09:52 PM
  4. davey11's Avatar
    Shoot when I had the Charge, I had about 70 fonts that you could install and show up on your choose font menu. I made a thread here and hosted them on megaupload. Well, I'm sure you all know about the megaupload fiasco, so they are gone.
    I did find 4 of em stashed on my comp. Just unzip and move them over to data/app with root explorer. They do not go in system/font. They will show up in your menu. Only for gingerbread.
    05-09-2012 03:35 PM
  5. t_kopta's Avatar
    Thanks
    davey11 likes this.
    05-10-2012 07:35 AM
