07-05-2017 01:32 PM
188 ... 23456 ...
tools
  1. Manojlovic Vaso's Avatar
    This is the solution!!!!!!
    Bravo!!!
    I was registered just to recommend this comment....
    Somdk likes this.
    09-08-2013 04:48 AM
  2. Somdk's Avatar
    Bravo!!!
    Great. Please be kind enough to share a small account on it.
    Android Central App....Rocks!!
    09-08-2013 05:05 AM
  3. V_uK_i's Avatar
    hei
    exuse me i have a question my wt19i cant mount sd card i dont now why i took the phone in my pc to take some photos and in the moment he broke and take a restart after the restart get noftifaticon a blank sd card a take a new sd card a insert to the phone but is the same wont to mount the card and the old card works by anothers phone i formatet ,factory reset, hard reset , flash a new firmware but dont wont to mount sd cards
    plsss help me any suug...
    thanks in advanced and exuse me for my bad english
    09-09-2013 03:13 AM
  4. Somdk's Avatar
    It might a device problem....take it to a proper service center.
    09-10-2013 09:26 AM
  5. milci's Avatar
    it didn't work in my PC
    the PC said "the type of the file system is RAW, chkdsk is not available for RAW driver"
    ???? helphelphelp
    09-12-2013 01:52 AM
  6. Dennis Castillo's Avatar
    Dude you're a genius!!!! thank you so much. You saved my life!
    btw... well explained. @mukundrathod111
    09-13-2013 05:11 PM
  7. missjess2006's Avatar
    I attempted to do this but I am still running into a problem.
    I am attaching a screen shot of my command prompt screen.
    ____________________________
    It is now working! YAY!
    09-17-2013 10:56 PM
  8. Somdk's Avatar
    There is no screen shot.
    There is no attachment.
    09-17-2013 11:17 PM
  9. nicoc208's Avatar
    This one helps, it's damaged SD card recovery step by step guide: recover data from damaged SD card
    hope this helps.
    09-19-2013 01:55 AM
  10. JPSid's Avatar
    dear..dear..dear....aaa tere haath choom loon...
    you really save my day...week...month...year....YES, my one year old 32G was showing damaged suddenly one day in Xperia-ZR & was used in HTC desire for more than a year. So, it means lots of data, photoes, files...everything... Luckily i found your post after so much so much of googling, tubing...& it WORKED IN FIRST ATTEMPT...!! So cool.....!!!!!
    So..iOS, Kitkat...WP8.1...CM10 or 20...whatever comes & compete...but basics are basics....you proved it & u are a master man.
    Thanks a lot again......
    09-19-2013 10:27 AM
  11. Christian Guinac's Avatar
    I tried doing the command but it said "Access Denied as you do not have sufficient privileges: You have to invoke this utility running in elevated mode"
    09-21-2013 12:04 AM
  12. Greig Berry's Avatar
    ???? helphelphelp
    I'm getting this too! any help?
    09-21-2013 01:03 PM
  13. liquidamber9's Avatar
    chkdsk /X /F <SD card drive letter>:
    Thank you so much! This was all it needed!
    09-24-2013 08:14 PM
  14. Sha Syed's Avatar
    i tried exactly above mentioned. but when i typed chkdsk /x/f G: it should scan and clean bad sect but an error message shown "cannot open volume for direct access". i tried all methods but its not working please help me out i dont want to loose 1000 pics.
    09-27-2013 01:29 AM
  15. Asim Raza Khan's Avatar
    Hi, i need help
    i have a SD card of 4gb.I accidentally removed it when it was formatting and now i didn't able to format it using Windows Format or Mobile formatting, when i try to format it gives me a Write Protect error, and when i did this "chkdsk /x/f G:" is says it can't do this on RAW . what i do, i want my card back please help me out...
    09-29-2013 04:43 PM
  16. pau009's Avatar
    please help me i also experience the damage in my 8gb micro sdhc kingston.. i try to insert it in other phones but it said that it is damage needed to format but when i try to format it is failed i also try the chkdsk but nothing happens it says "cannot open volume from direct access" what will i do? and when i click the logo in the taskbar if you want to safely removed the sd card nothing in there but a "...." and i cannot click it.. please help me..
    thank you in advance..
    09-30-2013 12:45 PM
  17. dhsu0701's Avatar
    Hello mukundrathod111 ,
    I am having the same problem. So, I tried your suggestion, but every time I do it , cmd gives me message: 'chkdsk' is not a recognized internal or external command, operable program or batch file. Is there anything I should do with the path or something like that? what path do i have to setup? Hope to get help from you. Thank you.
    10-04-2013 02:47 PM
  18. Jena Starr's Avatar
    Hi i am having the same prob with having error and it has all my daughters pictures from when she was born. I tried the run option but it telling me cannot open volume, I have a new hp computer. any help will be great appreciated. its file F.
    thanks
    10-07-2013 12:01 PM
  19. GhelSon TimCado's Avatar
    it says my device is raw???? what shoul i do??
    follwed your stepd perfectly..
    10-09-2013 07:59 AM
  20. Saksham Mahendru's Avatar
    buddy RAW means no file system is mounted on your sd card. .
    try using partition magic or similar software and then completly format your sd card to fix it. . .
    also if your data is imp . . recover it from any data recovery softwares. . .
    10-11-2013 05:30 PM
  21. Technologically challenged's Avatar
    I've been getting this same message on my S3 and am afraid to reformat it for fear of losing all my contacts. If the only issue is the videos and pics would it be safe to download everything on my laptop and go ahead and reformat my SD card? I am so not tech savvy so any help would be greatly appreciated.
    10-23-2013 10:30 AM
  22. jmmail1's Avatar
    thank you - this worked for me
    10-25-2013 10:50 AM
  23. JyriR's Avatar
    I managed to save my data with two different software.
    I installed HDD Low Level Format Tool to my computer. (link: HDDGURU: HDD LLF Low Level Format Tool)
    That was the program that recognized the corrupted SDHC-card, even the windows did not. Then I did a quick format with it. After the quick format, the PC was able to see this SDHC-card.
    Ok, now I can see my card, but the data...
    I installed Piriform Recuva tool to my PC (link here: Recuva - Undelete, Unerase, File and Disk Recovery - Free Download)
    And started the "deep scan". I was able to recover all my files, videos and pictures with it.
    Hope this works with you guys also. Good luck!
    10-26-2013 06:17 PM
  24. ThaDraGun's Avatar
    I think I Got it Finally.
    Recovering Data is not the solution Not even Formatting your SD card.
    I have the same problem after some days it doesn't load some Apps in Android when i check it in the settings it shows "DAMAGED SD CARD"
    I tried to connect with SD CARD Adapter slot in my Laptop but still couldn't detect and it asked to Format it.
    I tried to fix it with "CHKDSK" utility but couldn't do it through windows.
    But could do it with command prompt.
    Not if you have the same problem follow.....
    connect your SD card to computer.
    open command prompt.
    How ? .......
    open run from start button
    then type "cmd"
    now type
    If its K drive then
    chkdsk /X /F K:
    It will check your card and will repair it.
    Have patience it will take around 10 min.
    when it is done windows will detect your card evn your android phone.
    Have a nice day......
    THANKS!!
    This worked.
    Took 2 seconds to fix it.
    Edit:
    So it kind of worked. As soon as I stuck it in my phone it said it was corrupted again. I plugged it back into my pc and did the cmd again and the sd card was fixed again. However, I noticed almost all the files were gone. Only one folder of pictures appeared and all my apps are gone.
    The apps I dont really care about, I can replace those. The pictures and videos I cant tho.
    Right now Im trying PhotoRec (http://www.cgsecurity.org/wiki/PhotoRec) and so far it seems to be working. 105 pictures recovered and 4 videos.
    So do cmd so that windows will allow you to access the sd card then use photorec to recover any files that were lost.
    10-31-2013 08:21 AM
  25. Kamaluddin Rahman's Avatar
    mine is 16g class 10 micro sd card. its damage. pls help.
    11-05-2013 01:29 AM
188 ... 23456 ...
  1. Replies: 55
    Last Post: 08-31-2016, 03:51 PM
  2. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 10-11-2014, 04:47 AM
  3. Damaged SD card error?
    By bbasiaga in forum Barnes & Noble Nook Color
    Last Post: 09-01-2013, 12:41 AM
  4. HELP! "Damaged External SD card" Error
    By tarichar in forum Verizon Fascinate
    Last Post: 06-01-2011, 02:27 PM
  5. G1, sd cards, and pc mounting
    By hououtate in forum T-Mobile G1
    Last Post: 09-28-2009, 03:12 AM
