07-14-2011 12:25 AM
42 12
tools
  1. DroidXcon's Avatar
    I'm interested in rooting my Charge. This'll be the first time I've attempted this.
    My question is though when I'm looking through my phone's info I see to different things.
    My baseband version is still ED1
    However my Build Number is ED2
    Which on of these am I looking at?
    your build, you will need to install either a custom kernel or a custom rom
    may i suggest
    http://forum.androidcentral.com/char...ot-w-demo.html
    Nash Latkje likes this.
    06-01-2011 10:21 AM
  2. Nash Latkje's Avatar
    Thank You^^;
    I'll give it a shot.
    Assuming I don't brick the device I should always be able to restore it to "Factory Default" and try again.
    06-01-2011 10:41 AM
  3. DroidXcon's Avatar
    Thank You^^;
    if you are in a custom rom never do a factory restore,,,there is a seperate flash to recover to stock.
    but if you follow directions you will be fine
    06-01-2011 11:13 AM
  4. Nash Latkje's Avatar
    ._.; That sir is sound advice. I just flashed my phone to AB ^^; In fact my phone just talked to me, hah.
    All is well so far.
    06-01-2011 11:19 AM
  5. jayrell2289's Avatar
    yes there is an ed2 but it does very little
    06-02-2011 09:15 PM
  6. saillling4life's Avatar
    If you want to root do you still not update it or is there a way to get around it and still root?
    06-03-2011 06:04 PM
  7. bludragn#AC's Avatar
    thanks, good to know
    06-10-2011 10:41 AM
  8. sv_one's Avatar
    Would be great to know if EE4 can be rooted, now...?
    06-11-2011 09:51 AM
  9. winnersmw's Avatar
    +1. I'm thinking about getting a Charge very shortly and definitely would like to know whether I still need to do this or not. Considering all the ROMs listed in the Droid Charge Rooting, ROMs, and Hacks forum, I'm guessing no?
    06-19-2011 12:43 AM
  10. northbanker's Avatar
    Yes I too am considering getting a Charge and would like to know if it's OK to allow the OTA updates now?
    IOW, the root wizards have figured out a way to get around the ED2 problem.
    (Edit: I just saw in another ED2 thread that it says not to worry... rooting ED2 is no longer a problem. Phew)
    Note: I may never root this phone... I'm not super eager too, it just depends if anything isn't working well enough for me, in which case I *might* consider rooting.
    06-22-2011 12:28 PM
  11. jkeene81's Avatar
    I just flashed Altered Beast v5 after updating to the EE4 update and its working flawlessly. Im really glad didnt want to mess with flashing back to earlier updates and all that jazz. So go get your Charge and root away!!!!
    winnersmw likes this.
    06-22-2011 05:17 PM
  12. trailblazen's Avatar
    I keep getting a message to update but am afraid to since yall origionally said don't so is it really ok to now?
    06-23-2011 11:28 PM
  13. Dirrk's Avatar
    you can do the update
    07-04-2011 08:53 PM
  14. vhewitt29's Avatar
    this helped me with my choice to root thank you.
    07-06-2011 03:11 AM
  15. AirSushi's Avatar
    I rooted my Samsung Charge with Gummy 1.8.5. I was EE4 Stock. Very pleased that I did. The phone is MUCH faster. TouchWiz and the Verizon bloatware slowed the phone down terribly!
    A few tips using Odin. If at first the 'kernal' fails and you see the yellow icon depicting connecting the phone to a computer - do not panic. Odin is very very picky. I think I had to attempt to flash the 'kernals' 1-10 times each before I received a successful flash.
    07-06-2011 09:36 AM
  16. spuddyboy's Avatar
    like where
    07-08-2011 02:43 AM
  17. SuperJonCA's Avatar
    What the hell, MODS? This thread is confusing the heck out of people. It was stickied to help people, right? Well its outdated and is confusing. Please de-sticky and remove this thread.
    07-14-2011 12:25 AM
42 12
