1. hooskins's Avatar
    So before I start, mods feel free to combine this with the ongoing thread. I think it might be cleaner to have a thread for each review. I have broken my review into several sections.
    Background
    Previous Phones: iPhone 4(a week and forced by my company, not my choice), D1(for almost 20 months) , Palm Centro, Palm Treo and a series of Nextel theft-deterrent bricks.
    Alternate Phone Considered : HTC Thunderbolt
    Purchase Date: 5/14/2011
    Key Apps: Launcher Pro, Widgetsoid, Keyboard from Gingerbread, NoLED and LTE Switch.
    Accessories: Hard case/holster (found here, but bought it separately without the car charger). It has a kickstand, as well.
    REVIEW
    Design/Construction:
    • The phone has a very standard, but sleek, Samsung design. Very slim, jutting out towards the speaker. Also loving the physical buttons and the camera looks cool(Dodge Charger/Transformer logo-like). For some users the plastic-feel is an issue. It feels really light and almost flimsy. My added case increases weight, but still way lighter than the Thunderbolt. I enjoy the lightness but can see how some would want a heavier phone. In terms of sturdiness, no damage from a few falls(with case on).
    • Power button on the right side of the phone is a key difference vs. other phones, and something to keep in mind. Not happy with the omission of an LED indicator. Come on Samsung, is it really that expensive or difficult to have one? Learning to live without one. NoLED, from the Market, helps.
    Screen
    • The 4.3 inch SUPER AMOLED screen is all it is hyped up to be! Loving it and it was one of the key factors that put this phone in my A list. Colors are super bright, even in the sun. Read some reviews saying it is unnaturally bright. Not really noticing that. Seems more like Charge-hate than anything else.
    • Screen is made with Gorilla Glass, so a screen protector really isn't needed. The standard Verizon screen protectors also inhibit some of the brightness.
    UI/Performance
    • UI is horrible and to be honest it can be choppy with some of the stock widgets. Orange and brown colored windows/messages aren't that bad, but I hope to get rid of them soon. Also, I can see how 512 mbs RAM can be a limitation. I had to switch to Launcher Pro immediately to prevent any issues(also can be used to hide bloatware). Launcher Pro has been good and haven't had too many performance issues with it. Had one Launcher Pro FK/phone restart. It happened while I was away from my phone, so not sure what causes it.
    • Reviews have noted the keyboard isn't particularly great. Keys have quite a bit of space between each other, which lead to errors. I downloaded the gingerbread keyboard or use Swype so I don't have to deal with it.
    • Haven't used the messaging for more than 10 texts until I got my old friend Handcent downloaded. Lot's of orange and brown otherwise.
    4G
    • I am at the edge of a 4g zone in Northern VA. I get around 8.5 mbps down/ 5 up. Haven't tried it in DC yet, but have heard it is around 10-13 mbps. Haven't had the issue of 4G/3G/1X fluctuation. Over the last 3 days, it has dropped down to 1X about 3 times. Most of the times it drops in my office building, where my D1 use to always drop down to 1X.
    Camera
    • No problems with it so far. 8 megapixel camera has yielded some beautiful pictures. Flash has been good too. Haven't dabbled with the video much.
    Battery
    • There is a noticeable difference in battery life 3G vs 4G. I have been running 4G and Launcher Pro, with a decent amount of streaming radio and getting about 3-5 hours of life. I am sure the lithium ion battery will hold more of a charge, no pun intended, after a few weeks.
    Overall, I think its a pretty good phone. I am waiting to see how some of the hacking methods pan out, before I attempt it. That should get rid of any lingering UI/performance concerns, which honestly aren't that bad with Launcher Pro. Thanks guys and gals, I hope this helps!
    fundragon likes this.
    05-16-2011 09:32 PM
  2. Jaymil's Avatar
    About 8 miles outside of DC I'm able to pull in anywhere from 6 down up to 18 down. I get 12-13 pretty consistantly though.
    I'm really liking the phone so far coming from the Tbolt. I would like a bit more ram but it's not a deal breaker. The battery to me is not much better at all but I can deal with that.
    The only deal breaker for me, and I really hope there is a workaround/fix soon...is that I can't set it to LTE only mode. At work I'm on the fringe of the DC coverage area. My phone constantly goes from 4g to 3g and back when I'm indoors making it impossible to tether or do anything really if I keep it on auto..not to mention it rapes my battery.
    05-16-2011 09:56 PM
  3. jtalker1965's Avatar
    Every phone I ever had I turn off the the led. Don't need it flashing in the middle of the night. I wear a belt clip so it does me no good there. Just really don't see any need for it. Now maybe it works for you but it's just another item to drain the battery. Just my two cents.
    05-16-2011 10:49 PM
  4. KoukiFC3S's Avatar
    How bulky is the case? Looks cool with the kickstand.
    05-17-2011 04:03 AM
  5. hooskins's Avatar
    Case is made of hard plastic. It adds a bit of weight but isn't bulky. I would feel uncomfortable using the phone without it.
    05-17-2011 06:22 AM
  6. hooskins's Avatar
    To each their own I guess. I really need some sort of indication of emails as this is a work phone. Ive never had the issue of an indicator light bothering me at night.
    But I'm learning to live without it. The whole theme of my review is, most concerns about the phone can/should be addressed by apps/rooting.
    05-17-2011 06:25 AM
