1. BobR's Avatar
    When my Charge is docked in the desktop dock, I have all kinds of problems with the touch screen - it won't respond properly to touches or swipes.
    It seems to be either a lag issues, or a dock app problem.
    It's really bad - to the point that I can't even input my passcode to unlock the screen, or do something simple like scroll to another home page or adjust an alarm setting.
    Anyone else having this issue, and is there a known solution?
    05-24-2011 10:12 AM
  2. superstar1213's Avatar
    Does your phone work okay when it is not on the dock?
    05-24-2011 01:47 PM
  3. BobR's Avatar
    Yep...no comparison. Works fine when out of the dock.
    05-24-2011 02:39 PM
  4. superstar1213's Avatar
    I would take the dock back and see if another dock does the same thing, if so, then it means something is wrong with the software of the phone. Process of elimination ftw.
    05-24-2011 04:04 PM
  5. BobR's Avatar
    FYi, in case anyone else has this problem, it seems to be software related, and due to extreme lag.
    Still intend to try Go Launcher EX or Launcher Pro one of these days...
    07-13-2011 12:17 PM
