1. rorkin's Avatar
    would like to eliminate the start up sound.. Changing notification ring tone does not do it
    05-26-2011 08:36 AM
  2. Ken7's Avatar
    Did you try setting it to vibrate? Not sure if that works.
    05-26-2011 09:09 AM
  3. obi5683's Avatar
    Root the phone, then delete the audio file. Not sure where it is on the Charge. Try looking in /system for a resources or customizations folder. On stock Android (or AOSP ROM's) it is in /system/media folder. You are looking for an MP3 file. On the DInc, the file names are VZW_droid.mp3. Could be similar.
    05-26-2011 09:45 AM
  4. rorkin's Avatar
    Will do once phone can be rooted.. Unfortunately update was applied b4 I knew of the problem with rooting
    05-26-2011 10:03 AM
  5. deadpenguins's Avatar
    Settings > Sounds Settings > Volume > turn System Volume all the way down.
    johncallicrate likes this.
    05-26-2011 10:18 AM
  6. rorkin's Avatar
    Seems to work.. thanks
    05-26-2011 11:10 AM
