If so are you having trouble with it automatically updating? No matter what I do it seems to be a struggle to get the location to update properly. I keep getting a pop up saying "failed to update location no signal" even when all 3 GPS providers are on. On my Thunderbolt I didn't even have to turn the GPS on and it would update fine just through the cell tower locations. Now im having to turn all 3 location services for it to update the city im in and even then its slow to update. Im having the same issue with Beautiful Weather widget also.
I don't use gps unless I travel. I have it set to update hourly and have it on a set location.
See I could do this on the Thunderbolt just fine but with the Charge it wont update unless the GPS is on fo some because I keep getting that no location signal pop up.
See I could do this on the Thunderbolt just fine but with the Charge it wont update unless the GPS is on fo some because I keep getting that no signal pop up.
Huh? I am just as lost on that one. I hope you find a solution quickly, weather bug is the best application like that out, love how accurate it is.
I'm using Elite myself and don't seem to be having an issue. I'll keep a closer eye on it tho during the day as I have it set to update every 2 hours. FYI I don't use the GPS setting tho as I never turn GPS on unless I have to. I just have Enable My Location, Enable Follow Me, and Use network checked.
I have a Thunderbold HTC via Verizon, and I WAS getting the
"failed to update my location no signal"
issue, but I just removed the WeatherBug app and that got rid of it. Weather.com's app works well also. Just a slightly different format. Weatherbug also has a Window's app, that seemed to be very ad supported. Deleted that one too.
