I'm not getting the update yet for some reason, even when I go into system updates within settings it says my phone is up to date although I'm on ED2 still, guess it'll get pushed when it gets pushed...
there you go fear , im deodexing now
1e96b63a1f25.SCH-I510_ED2_update.zip
Anyone know if this interferes with the root or a custom ROM?
As for rooting there's always the possibility that an update can cause trouble when trying to root a phone, but in some cases not. Either way I'm positive this update is being looked at by the right people and they are taking the necessary steps to make it rootable asap if it isn't already. As for a custom rom, it won't matter as the rom will replace this build with whatever build the rom is centered upon.
there is no way to root these newer builds, a custom kernel needs to be installed :-\ but fortunatley thats just as easy if not easier then going through the trouble of manually rooting
Oh, nice, yeah I agree with you. Looks like I have new things to learn haha! Btw, you were so right about this phone, it's amazing so far!
told you man
im sure that the fascinate may seen this happening soon also where they find and patch all the security holes
im going to build a new altered beast tonight if i can get this deodexed in a timely mannaer
but yeah you need to go back to stock and then update your way to EE4 then flash a rom or kernel
I tried loadling this as an update file on my phone via CWM but it starts then gives an error every time.
Any ideas?
woot. Can't wait to odin/flash it
Sent from my SCH-I510 using Tapatalk
