DroidXcon
So if we are running altered beast we have to return to stock in order to apply this update to then update the radio?
unfortunately there is no other way
So how do we go back to stock. I'm very new to odin
So if I'm understanding correctly, this update is really only usable for stock users, as custom ROMs (as of right now) will just revert the entire phone back to a pre-EE4 build?As for rooting there's always the possibility that an update can cause trouble when trying to root a phone, but in some cases not. Either way I'm positive this update is being looked at by the right people and they are taking the necessary steps to make it rootable asap if it isn't already. As for a custom rom, it won't matter as the rom will replace this build with whatever build the rom is centered upon.
Forgive me for being a novice here. I've been 3 years on iOS. How it worked there is if there was a new FW update by Apple and you were jailbroken, you simply never installed the official release. You had to wait until developers made their own custom version of that latest firmware and installed that. It sounds like that is the case here?
I got that part, I was speaking in regards to applying the update straight from OTA or having to wait for a "custom" EE4 package to install.we already have it rooted and already have what we need to build custom roms im just having a little problem with my sdcards i dont know if it was the update that is making the card write protected or what ...it could just be my phone lets hope thats the case for everyone.. not so much for me though lol
I dl the update zip put it in root of my sd card, then i go to recovery mode vol up+home+power then i use vol button to select then hit home button do update but then nothing happens just goes back to the triangle WTF!
What exactly is odin? Sorry I'm very new to android rooting and don't know anything.
Does this update fix the browser lag with java?
