reflekt2099
You need to disable Voodoo before doing anything else. Reboot into CWM, disable Voodoo lagfix and reboot again. Use Odin to Flash the "Rooted Stock ED1 Downgrade from ED2" ROM, accept the ED2 OTA update as you did before. Then you copy the file that DroidXcon put in this thread on your SDcard, rename it to Update and reboot again into CWM, apply the update file and you should be all set.
It also sounds like DroidXcon will have an updated version tonight. I hope this helps, but if you do not disable Voodoo it will seriously mess up the phone (I know from personal experience).
can we simply put the "disable_lagfix" file back into the voodoo folder on the SD card to Disable Voodoo Lagfix? or do we have to disable lagfix in CWM?
