Bravozero
Drroooiiiiddddd
Try to boot into cvm and disable lag fix then you will need to flash the ed2-ed1 downgrade accept the updates then you should be good make sure you clean the cache as well
Sent from my SCH-I510 using Tapatalk
That worked, thank you. The CWM works great as well. Going to do a factory and cache wipe and start from fresh with the ED2-ED1 flash. Do I still have Voodoo and the file structure associated with it or will I have to go through that process again?
