New to all of this but am interested in the update, as my phone isn't doing HotSpot I'm assuming I haven't had the update pushed to me. Do I have to be on a G4 network to use/install update and how do I utilize the zip file earlier posted to install the update?
I know it is tempting to d/l the ZIP file posted earlier. But you might want to wait -- one never knows with these things; could be there's a bug in the update [being pushed out by VZ and potentially captured in the ZIP file] and that's why it is rolling out slowly (they're fixing it?), or could be the ZIP file isn't what it is cracked up to be [because VZ changes the update on the fly as needed]. No-one knows.
To fix your HotSpot isn't that hard:
1) d/l Elixir App:
https://market.android.com/details?id=bt.android.elixir
2) go to the menu screen (far left hard button), choose WIDGETS
3) add a 1x1 bar widget (or whatever size you want) (do not close/save yet)
4) click on a blank spot on the bar before you add it, include the "Wi-Fi- AP (Hotspot) switch"
5) Save
6) Now you can turn on/off the hotspot whenever you want
That's pretty easy -- easier than downloading an unknown ZIP update...
plus you might like Elixir.
The only issue I had with it is that I needed to change my hotspot settings. (The settings screen won't even work anymore!) To do that, I just changed the date to 5/15, changed the settings, changed it back, all without leaving the settings menu, so didn't cause much disruption in the calendar/etc. area.
You'll get the update eventually -- why rush it if this is your only issue?
Hope that helps.
