1. TerryMasters's Avatar
    I just got this phone, loving it so far, but I wanted to know whether or not it can connect to Wireless-N 5Ghz networks before I go breaking my *** trying to make it do something that isn't going to work no matter what.
    The 5Ghz network isn't showing up on the list. Should it? Am I the only one who can't connect to a 5Ghz network?
    06-11-2011 05:34 PM
  2. delco714's Avatar
    PhoneArena states it can - "Wi-Fi 802.11 b/g/n"
    However, though it surely can do the N 2.4, I dunno about 5. Considering N is just MIMO g, why go for the 5 anyways? Were you having problems with your wireless landlines and interference at home?
    06-11-2011 06:39 PM
  3. dubge's Avatar
    I have a N/G dual broadcast router and it will see my G network but will not see my N (5ghz) The Thunderbolt also did not see 5Ghz N networks
    06-11-2011 07:24 PM
  4. delco714's Avatar
    funny enough, I just upgraded to the basic wireless N linksys router from the ghetto original G linksys. I set it up with a WPA2 Personal and it connected immediately after I put the password in, no problems here. Yet, I dont know whether I am using the G frequency or the N, but I would have to assume im using 5ghz N with 40 mhz channel width.
    06-13-2011 12:37 AM
  5. dubge's Avatar
    what router is it? I doubt it is the 5ghz you are on
    06-13-2011 05:21 PM
  6. delco714's Avatar
    Link sys wireless n. Wgt160 ver 3 I think
    06-15-2011 09:18 AM
  7. dubge's Avatar
    I am almost positive that is 2.4
    06-15-2011 10:30 AM
  8. chadness's Avatar
    Defaul is usually 2.4 ghz only, so if you didn't specifically set it to 5 ghz, it's 2.4.
    06-15-2011 10:38 AM
  9. delco714's Avatar
    i dunno. i only have the chocie of "20 mhz or 40 auto" or 20 only. cant choose the 2.4 or 5. :\. Either way. I have it on N-only connections, and my wifi is much improved in stability, speed and range.
    06-15-2011 12:14 PM
