1. RLLangley's Avatar
    I have a 2010 Civic with a USB aux in and the only way I can get the Charge to work with my stereo is plug it in and then turn the stereo on/off. Then it just treats the charge like a mp3 CD. Seems like each artist has their separate folder. I use iSyncr to sync so not sure if that is an issue.
    Anyone have this problem and have found a solution?
    Thanks.
    Major thing I do want is have playlists.
    06-12-2011 06:16 PM
  2. waterfrontmgmt's Avatar
    does your car not have bluetooth? i have a camry and i listen to slacker and tune in radio streamimg all the time through bluetooth.
    06-12-2011 07:56 PM
  3. RLLangley's Avatar
    Nope the Si doesn't have bluetooth
    06-12-2011 09:05 PM
  4. dgcamero's Avatar
    You don't just have an aux mini jack input?
    06-13-2011 11:28 AM
  5. aschindler's Avatar
    I have an aux mini jack input and use it to listen to Pandora. My Mercedes has a pretty nice Harmon Kardon sound system and I have Pandora set to "high quality". I'm very pleased with the sound and Verizon's network. We're still on 3G in Milwaukee.
    My one wish is that the text on the Pandora app was larger so I could more easily read the name and artist of the song currently playing with a quick glance while driving.
    06-13-2011 12:18 PM
