1. AndroidXTC's Avatar
    In fact its less than two weeks old Mfg. date 6/3/11 see pictures below. Well Tech support was right it was a hardware issue not being able to load some of my apps to the old phone after the update. I loaded everything on fine then did the update and everything is working well now.
    06-13-2011 07:25 PM
  2. Ken7's Avatar
    Why do you think it's a new phone? The replacement phones are supplied with the same plastic coverings the new phones are. Most of the time refurbs never really look like refurbs.
    06-13-2011 07:37 PM
  3. AndroidXTC's Avatar
    The supplier is Samsung on the tag not New Breed Logistics the Company that Refurbs all of Verizon's handsets.
    06-13-2011 07:42 PM
  4. ellje's Avatar
    Looks like you got your panties in a bunch over nothing!
    06-13-2011 07:46 PM
  5. AndroidXTC's Avatar
    I know
    06-13-2011 10:56 PM
