Hi, It seems that the wireless will not connect to a router that has the essid turned off or not displayed. This is at lease an issue for the Charge that I picked up. I'm only a week out with the device and am overall happy with the exception of the next issue.
It seems that recently my display seems to take a few seconds to initialize after hitting the power button, rather a very slow pausing fade in. At it's worsts it will not display the objects on the desktop/home screen after transitioning from a different layout such as Applications. I believe this started after the EE4 update as I do not recall that happening out of the box. This is not rooted and is all stock and I'm not referring to the overall lag that this phone is known for, that I can handle.
Has anyone experienced the display issue I've noted above?
your thoughts on returning the device?
