1. AndroidXTC's Avatar
    Still 35% left.
    06-18-2011 11:14 PM
  2. mboverst's Avatar
    Glad to see it's finally working out for you!
    06-19-2011 09:53 AM
  3. AndroidXTC's Avatar
    I think you just have to give the batteries time to condition themselves. Also this is not a laptop computer or a tablet its a PHONE, I think some people are on the internet all day long then they ***** when they only get 4 or 5 hours out of that tiny battery. I used this phone all day long took and made calls even had it hooked to my cars bluetooth system for an hour and even surfed the net a few times and still got well over 18 hours out of her.
    06-19-2011 11:13 AM
  4. saillling4life's Avatar
    Have you made any significant changes from when you first got it.
    06-19-2011 11:19 AM
  5. izzo00's Avatar
    how did you maintain the battery
    06-19-2011 11:22 AM
  6. AndroidXTC's Avatar
    Nothing special. At the end of my day I usually have between 25 to 35% left then I charge it till its full.
    06-19-2011 11:30 AM
  7. brianct1972's Avatar
    Can I have your battery?
    06-19-2011 12:13 PM
  8. AndroidXTC's Avatar
    Honestly Brian, I just think a lot of people out there are using these handsets way over the designed in capabilities of the handset it was never designed to be used as a laptop or tablet replacement.
    06-19-2011 12:33 PM
  9. hooskins's Avatar
    Brightness, 4g, phone usage (particularly data usage) and gps are some of the key variables.
    06-19-2011 01:29 PM
  10. AndroidXTC's Avatar
    Im always in 4G in Chicago My brightness is set to about 65%
    06-20-2011 06:21 AM
  11. hooskins's Avatar
    I meant to say brightness particularly auto-brightness. The constant changing of brightness kills battery.
    Additionally switching back and forth between 4g can kill battery too. In the DC suburbs we are at an edge of a 4g region and it tends to fluctuate. When I'm on the road in Houston it rarely changes and my battery life is longer.
    06-20-2011 06:48 PM
  12. trifecta's Avatar
    My screen is set quite low and even with moderate use won't get 18 hours out of it. If I turned the 4G off and just let it sit in standby that might work.
    06-23-2011 07:57 PM
