1. TerryMasters's Avatar
    I don't know about you, but if something happens at a certain moment I like being able to record it. If your Charge's battery goes into the yellow, you can no longer record video.
    Anybody else think this should be a warning instead of something that kicks you out of the app? Maybe I want, or need to record something regardless of whether or not my battery is low. Because of the current situation, I don't have that option.
    "Well I could've gotten that criminal's face..."
    Edit- However, I realize now that it might be disabled because it doesn't have enough power to run the camera itself - but considering how much longer my phone lasts once it's in the yellow I find this extremely unlikely.
    06-19-2011 10:48 PM
  2. m_usman_ch's Avatar
    Yes battery should be warning and not a problem, though here is the workaround for this:
    https://market.android.com/details?i...wbatterycamera
    10-29-2011 10:21 AM
  3. W_A_Watson_II's Avatar
    Just be careful, there is a current issue with Low Battery/over amperage draw that killy the phone, and you have to pull the Battery to get the phone to re-boot.
    Camera flash kills / shuts down and locks up Droid Charge
    10-29-2011 03:15 PM
