1. shobuddy's Avatar
    I'd like to know how file storage on the Charge works. Like if I download apps, music, etc., are certain file types designated for internal memory and others for the microSD? Or do all files by default go to the internal memory till it is full and then once the internal is full, the microSD is used? Or...
    06-22-2011 11:10 PM
