05-16-2013 12:13 PM
42 12
tools
  1. vols fan's Avatar
    My wife has this issue on her TB all the time. This is not a Charge issue its a VZW issue. I have had my Charge for 3 weeks now and the only time I had this issue is for the 30 mins I had juice defender installed.
    07-21-2011 08:07 PM
  2. nsdjoe's Avatar
    I often will be stuck in 3G (despite being in downtown Chicago with full LTE strength under normal circumstances), and have to cycle in and out of airplane mode a few times to get it to switch to 4G. One out of maybe every five times this happens I have to reboot the phone entirely. A few times it's just been NO data until I reboot.
    It's horribly inconvenient and I hope VZ comes up with a fix.
    07-21-2011 09:17 PM
  3. piizzadude's Avatar
    I was reading some stuff on this earlier today. There appears to be an issue with switching from radio to wifi and back again. it seems to take anywhere from a few seconds to a few minutes for the radio to fire back up.
    Yep, it falls under the whole "known issue and will fix in the next release" umbrella.
    Personally. I have a VERY strong 4g signal and havent seen it drop yet. The only reason why I looked it up is because I turned the 4g off to see what kind of effect it would have on the battery. Then it wouldnt turn back on. Researched it to make sure it wasn't the ROMs fault (ABv5)
    07-21-2011 10:03 PM
  4. atlantar6's Avatar
    No juice defender but same thing here. I can usually switch mobile data off and on to get it to work but sometimes a full reboot is needed.
    07-22-2011 07:15 AM
  5. PeterDLai's Avatar
    I get random dropouts in connectivity, all while on 4G (with the 4G LTE icon displayed prominently throughout the dropout), which seems to be less common (most people seem to complain about loss of connectivity with a coinciding switch to 3G/1X or with the 4G icon disappearing, not so in my case). It seems with more recent radios, the connectivity will eventually come back within a few minutes without me needing to do anything, but it is annoying nonetheless when it happens. If I want a more immediate fix, I can toggle it to CDMA mode and back to LTE automatic and 4G almost always comes back right away and works immediately.
    The Anandtech review of this phone mentions the same exact issue as me, and the reviewer also told me it was something that he only experienced on the Charge, not on the Thunderbolt/Revolution (which he also reviewed).
    07-23-2011 07:47 AM
  6. ups2525's Avatar
    I have been on ABv5 since day one it became available and have had no issues with a data connection til' the past week...now I rarely get a data connection! At first a hot restart would get a data connection but now nothing and its when Im on CDMA auto and 4G both...EXTREMLY FRUSTRATING! I wiped everything and it improved for a while but after a few hours loss of connection AGAIN!
    07-24-2011 01:22 AM
  7. piizzadude's Avatar
    got a link for that? i have listen to a few of the reviews by AZ and havent heard the Charge mentioned with the TB...I am interested in hearing it
    07-24-2011 02:37 AM
  8. PeterDLai's Avatar
    The part where the reviewer talks about the issue is on this page. The quote below is the actual excerpt from that page.
    My only complaint is that every once in a while, the LTE data session sometimes stalls briefly – sometimes for a a few seconds, other times for a few minutes. When that happens, you’ll see the uplink green arrow blink, but no orange downlink arrow. Rebooting the device fixes things.
    I e-mailed him asking if he experienced this issue with the Thunderbolt/Revolution (also reviewed on Anandtech, linked them as well) and he said he didn't.
    07-24-2011 09:53 PM
  9. rbess1965's Avatar
    I know this is an old post but I'm starting to have these issues. Mostly noticing it when trying to fire up my Sirius app in the mornings. My routine is to activate Wifi when I get home from work, then during sleep i have wifi & bluetooth deactivated but I never change data. It just stays on. Next morning I try to fire up Sirius and get a data connection problem that only a reboot will fix. Seems to be getting worse.
    07-26-2011 02:03 PM
  10. h_cl's Avatar
    Most of my headaches are a result of the 'dual case' incipio hard case I bought at Verizon. With it on I have intermittent data connection and drop call issues. Just now for example, I couldn't make a solid connection for a mobile hotspot. As soon as I take it off I am problem free (and on 4g!) for an entire 60mi commute in and out of LA.
    My girlfriend has the gel case from Verizon and I suspect even that might have an effect (not nearly as bad). The phone will show up and down action and a strong signal strength but I think its dropping data packets.
    07-26-2011 07:16 PM
  11. Chris2183's Avatar
    I get random dropouts in connectivity, all while on 4G (with the 4G LTE icon displayed prominently throughout the dropout), which seems to be less common (most people seem to complain about loss of connectivity with a coinciding switch to 3G/1X or with the 4G icon disappearing, not so in my case). .
    Here is a typical day in the life of my Charge
    Here is an interesting story I would like to know more about , let me click the link
    30 seconds of loading later
    Im really starting to hate this phone.
    07-26-2011 08:22 PM
  12. atlantar6's Avatar
    Dude, look up in the right hand corner. You have bluetooth but no cell connection. That is the circle with the x. What really sucks is when you have full 4g and get the message.
    07-26-2011 08:30 PM
  13. Chris2183's Avatar
    It does it with or without the bluetooth on.
    07-26-2011 08:48 PM
  14. h_cl's Avatar
    I have the same problem every day in the same spot. It only occurs in the afternoon and only on 4g. It will show 4/5 bars 4g but either I see no data being transmitted or the phone loops the same up/down pattern over and over. When I drop down to 3g (sometimes the phone does this) I'm good to go. When I move a few miles from that area I get solid 4g again. I'm optimistic that Verizon will fix this; its not just a problem for the Charge.
    07-27-2011 08:21 AM
  15. Ken7's Avatar
    Wish that were the case for most of us. Mine is naked and I get frequent 'no data connectivity'. I think in the vast majority of cases it has nothing to do with the case.
    I also don't expect a fix for this ever as VZW is not to be heard on this at all. Only one post from a VZW employee said 'we're aware of the issue and working on a fix with Samsung'. It aint happenin guys. The only 'fix' is a newly designed phone IMO.
    07-27-2011 10:43 AM
  16. rbess1965's Avatar
    Luckily I didn't have super high hopes for this phone. My main goal was to try to choose the best of the 3 available to secure a 4G unlimited data plan. I'll probably end up passing this one on to my kid and get one of the new dual core 4g phones when my next upgrade becomes available. Of course that will depend on the price tag. Will keep my fingers crossed that they will fix the data issue someday either with an update or maybe with GB. I really hope so because other than this issue, I've been very happy with this phone. Light weight, battery life & display are big plus'.
    07-28-2011 12:44 PM
  17. Rob Montesa's Avatar
    I got the same problem too.. always showing no data connection and its really pain in the *** when I update my apps.. but when I transfer my sim in note theres no problem I encounter in data connection.. I really disappointed with the s4 right now..
    05-16-2013 12:13 PM
42 12
