Just curious, those of you getting excellent battery life, are you using an extended battery or just the stock?
Today was my first full day with my Charge, and it managed to go strong from 7:30 am until 8 pm, and by 8 it was only down to 30%. This was a mixture of 3G and 4G.Ive got the stock battery,in 3G area only, rooted and overclocked and I get at least 12 hours if not 14 with moderate use. Im pretty impressed but sounds like 4g battery life is a whole other story! Looks like most of my use is the screen of course but its hard to dial down the brightness becuz the screen is so impressive!
Turn off the setting that lets applications update in the background and the location services. Then when you shut off everything it will sip battery life.
My battery life has been extremely horrible since ive owned this phone. I will be lucky if i get 10hrs from this phone and this is from very light use w/ wifi, btooth, turned off, maybe 1-2 phone calls all under 5 minutes of talk time, about 5 texts throughout the day, and about 10-15 minutes of web browsing. Pathetic battery life. Problem w/ unchecking Background data is then you cant go into the droid Marketplace.
Are you in a crappy 3G market? I have noticed that a bad 3G signal will suck the life out more than a gold digging wife....
