1. MaxBuck2's Avatar
    Anyone have any success working with this software on their Charge? I can't get the software to recognize the phone to connect using Bluetooth, WiFi or USB.
    06-30-2011 10:08 AM
  2. graybeardnc's Avatar
    I use MPE and you're right, it can be tricky to get connected. On the Settings screen of the PC app, there are some small Help links with some good tips for the different connection types. Just use the KFWI method. I've been able to connect using all 3.
    Good luck.
    06-30-2011 09:53 PM
