1. Droid800's Avatar
    So I attempted to play music I put on the SD card today, and got a 'this file type is not supported by this handset' message. Why am I getting it? I was under the impression that all android handsets could play back AAC encoded content. Can the charge?
    Sent from my SCH-I510 using Tapatalk
    07-03-2011 07:06 PM
  2. LocrianGroove's Avatar
    I haven't had problems playing back AAC files on my Charge. I've played files from the iTunes store, as well as stuff I've encoded using the Nero AAC encoder.
    Are you having success with non-AAC audio playback, or is AAC the only one you've tried?
    07-03-2011 10:12 PM
  3. Droid800's Avatar
    Funnily enough, as soon as I posted it it started working. Totally random.
    07-04-2011 12:04 AM
