reb422
Phil... in the last podcast you said you wanna write about phones and "help people decide what to buy"... so why did you refuse to help me choose between the DNA and the GS3?
Just a note here my wife has an iPhone 5 and with her use which I consider light to moderate (normally under 1Gb a month) if she isn't on WiFi her phone barely makes it and days that she does have heavy use she has to charge midday.. (actually I should say she *should* charge midday.. but normally forgets..)
Sent from my DROID RAZR HD using Android Central Forums
For those that need more storage, and/or more battery power, the Droid DNA was almost the phone for you, but, it is not. You will need to look elsewhere, or, wait, for the perfect phone for you.
The Verge just killed it on battery life...rut-row.
Maybe While you can't compare a note2 battery size to DNA I also read the various battery reviews for several phones (note2/N4/G3)
The DNA was the only one to undergo the Verges Battery Test, all others were 'user' type impressions.. so even there they are not consistent in their review
I would have like to see a larger battery, but after Phils useage and comments of RealWorld use I'm not sure it's as bad as they 'artificially' made it sound
The J Butterfly is waterproof. Could the usb flap on the DNA mean that it is waterproof also? That would seem logical.Slice and dice. :-/
No....that sucks. Doesn't it not install or just not work?
will try to remember to do this when i get homeWould someone kindly test the DNA dB signal strength (actual numbers) side-by-side with other phones, e.g. GS3, Razor, etc.?
I currently have a DInc2 and signal strength is not the best.
No friend stream, was deemed a 'battery hog'I want to know if the DNA has Friend Stream?
I have never had an HTC phone before but when I used play around with my brothers Incredible I liked Friend Stream so much. So much so that I made an account and my first post asking about it.
not at all, i deleted the widget... outta sight, outta mindDoes all the Amazon stuff fundamentally change how you use the phone?
How long does it take to boot up?
That's gotta be with fastboot on.
NightAngel79, does disabling a lot of the apps help with performance and battery? Also, does Sense get in the way of the experience.
Oh, and how often is your phone on 4G LTE, and does it hurt the battery.
Sent from my SCH-I535
Their review of the Motorola Droid Razr HD included the same battery test, and that phone's 2300+mAh battery lasted nearly 10 hours (which shocked them). The other reviews I checked however (the LG Optimus G and Nexus 4 and Nokia Lumia 920) did not report the results of any battery test, just user impressions. Then again, I expected the battery life for the DNA to suffer if you had the screen on for long periods of time, so this doesn't surprise me too much.
I guess the question then is (if battery life is a concern) what you plan to do with the phone, and your everyday situation. If you're in an office all day with wi-fi and/or an outlet nearby, the battery shouldn't be an issue. If you don't check your phone often and just need good standby, anecdotal evidence in this thread also suggests you'll be fine. On the other hand, if you are often on the go and on a cell network, and like to stream movies/vids or are a heavy gamer, this may not be the phone for you. It's all about balancing your needs with your everyday environment.
Personally, I find the description of lag in the Verge review more disconcerting than what they say about the battery. Any early owners able to confirm or counter that point? Chrome seems to be the biggest culprit, based on the review.
