osubeavs728
Means a lot until u pick the phone up and use it completely different than the reviewer and go "I only got 12 hours of battery life should I send my phone back?"
Sent from my SAMSUNG-SGH-I717 using Android Central Forums
Well using this logic every person is going to get a different amount of battery life. Real world reviews are helpful, but not absolute. Because no one is going to use the phone the same exact way as you, in the same exact conditions Everyday. The only thing that would tell you absolutely if the battery life is "good" (subjective) is to test it and see if it meets your personal needs.
