Hi does anyone know if the DNA is supposed to support simultaneous voice and data while on 3g network I know that it works with 4g my question is if it also works while on a 3g network.
Oh so you are saying that you are going to be 3G only (no LTE into the equation at all)?
Not sure about that one since voice is 3G...
Why is it different then the rezound which worked simultaneously on 3g as well and the galaxy s3 also works.is there a reason this phone is different
And the galaxy s3 does work simultaneously?
The SGS3 does work with 3G and data, I just tested it out.
I am on Sprint which is cdma, just like vzw.
Yes, I turned off 4g,had to reboot, turned off wifi, made a call to my voice mail, hit the home button and went to espn. Saw how badly the Steelers lost and laughed
Sent from my X-Band Modem... TY Genesis
