1. c10ne's Avatar
    Does This Look Normal?...Something is keeping my phone awake and for that reason I haven't used it much and The Battery is Draining when supposed to be sleeping..any help would be Great Thank You
    Sent from my HTC6435LVW using Android Central Forums
    Attached Thumbnails What apps are You Using To Get Battery info?-uploadfromtaptalk1358540513768.jpg
    01-18-2013 02:22 PM
  2. croppz's Avatar
    I use GSam and I'm pretty sure it'll show you which app is keeping your device awake. I haven't fully messed with it though. But it's a great battery app.
    01-18-2013 02:39 PM
  3. Lactose The Intolerant's Avatar
    Another vote for GSam Battery Monitor... very handy (and very free)
    examples from dev:
    01-18-2013 03:17 PM
  4. c10ne's Avatar
    Thanks I just Restarted my phone and Now its Sleepy lol I'll look at that app Thanks Again
    01-18-2013 03:27 PM
  1. Replies: 2
    Last Post: 10-14-2011, 03:08 PM
  2. What app are you using for screen captures?
    By exitrow in forum T-Mobile G2x
    Last Post: 09-28-2011, 10:30 AM
  3. What apps are you using most or found very useful?
    By Staticpunk84 in forum AT&T Inspire 4G
    Last Post: 06-02-2011, 05:55 PM
  4. What Apps are you going to install first?
    By mikepr in forum Motorola Xoom
    Last Post: 02-23-2011, 12:21 PM
  5. What apps are you using that require root?
    By easy1jay in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-11-2010, 02:37 AM
