1. AndroidXTC's Avatar
    I did a sync and some of the albums duplicated I just cant figure out hoe to delete them direct from the device. Thanks
    02-20-2013 07:12 AM
  2. ddsdavid's Avatar
    Open the song list, to the right of the song title is three dots. Tap the dots and a menu will have delete.
    Sent from my HTC6435LVW using Android Central Forums
    02-20-2013 08:40 AM
  3. bellken's Avatar
    From, a post I made a while ago --
    If you use HTC sync manager, it will include the path for the folders, and, it will store your data in /sdcard0/mobile/
    And, by path, I mean the path on the pc, you sync'd your data from. My music was getting stored in /sdcard0/mobile/music/c/.../music/
    I found this when I was seeing 2 copies of all of my music folders. I started deleting some, and, some of them were still showing up after I had removed them from the Music folder (/sdcard0/Music).
    02-20-2013 10:02 AM
  4. AndroidXTC's Avatar
    Exactly what was going on with me Thanks guys.
    02-20-2013 10:06 AM
  5. Devon Estes's Avatar
    I went to my song list and clicked on the 3 dots and all it says is: Add to queue, add to playlist, go to artist, go to album.
    No delete option. Any other suggetions?
    05-24-2013 09:07 AM
  1. Replies: 14
    Last Post: 11-21-2019, 08:29 PM
  2. How do I delete songs on my phone w/out plugging into the comp?
    By Chilly818 in forum Verizon HTC Thunderbolt
    Last Post: 09-03-2015, 12:02 PM
  3. How do I delete a device from the Android Market?
    By KahneFan in forum Android Apps
    Last Post: 04-26-2012, 01:28 PM
  4. How do you delete a reminder in the Calendar
    By oma1340 in forum Verizon HTC Thunderbolt
    Last Post: 03-30-2011, 09:01 PM
  5. How do you delete saved pictures from the EVO?
    By DocPeanut in forum HTC EVO 4G
    Last Post: 06-06-2010, 10:48 PM
