01-26-2016 09:51 AM
32 12
tools
  1. trilianleo's Avatar
    I am getting horrid. I am now using more than I am getting from my charger. Overnight phone only got to 70 percent. Can't find apps with task manager running slow. Do not want to have to reset it.
    05-03-2014 11:39 AM
  2. dasaucemasta's Avatar
    For me, the biggest reason for the battery drain seems to be phone radio. Phone radio has used 60% of my battery and it's just been sitting on my desk all day I haven't even used it.. any way to stop this?
    Sent from my HTC6435LVW using AC Forums mobile app
    Attached Thumbnails Massive battery drain since 4.4.2 on Droid DNA-1399393744711.jpg
    05-06-2014 11:30 AM
  3. Bass Master's Avatar
    mine drains even while charging
    10-09-2015 09:34 AM
  4. Bass Master's Avatar
    my htc dna is now draining while charging this is ridiculous
    10-09-2015 09:37 AM
  5. Kaitlynn Gibson's Avatar
    Yeah, mine has too! It gets to 50% withing 6 hours of light activity. I have to carry my charger with me everywhere. I've even tried using the 360 Security app that has a battery booster.
    Nothing seems to work,
    01-21-2016 08:13 AM
  6. Imnutsnj's Avatar
    You can try to recalibrate the battery, there is a bunch of information on how to do this on several forums. To give you a quick idea of what to do, you essentially hold down the power, volume up and volume down simultaneously for 2 minutes, do this with the phone plugged into the charger. The phone will reboot several times, but keep those 3 buttons pressed until your 2 minutes are up. Be sure to have have at least 10% battery. I hope this works out for you.
    Frank
    01-22-2016 07:17 PM
  7. Copachick's Avatar
    I have actually been having the same issues. Maybe not right after that update, butall of a sudden my battery is just dying twice as fast when im not even using it often. I now keep a charger with me at work. Very strange.
    01-26-2016 09:51 AM
32 12
  1. Who is NOT Updating to 4.4.2 on the Droid DNA?
    By xtcFlash in forum Verizon Droid DNA
    Last Post: 05-02-2014, 04:12 PM
  2. Wondering about Sprint Unlimited Data/tethering plan on my S5?
    By cybermink in forum Samsung Galaxy S5
    Last Post: 04-27-2014, 11:55 AM
  3. Which fonts do you use on your M8?
    By manni1to in forum HTC One M8
    Last Post: 04-26-2014, 02:26 PM
  4. Samsung Galaxy Tab 2 Won't turn On
    By john paul reyes in forum Samsung Galaxy Tab 2
    Last Post: 04-25-2014, 11:30 PM
  5. Show text sender on lock screen - android 4.0.4
    By pawprints86 in forum Samsung Captivate Glide
    Last Post: 04-25-2014, 10:43 PM
