mckray
Wait Wait!!! Don't reset!
I ran into the same problem, it was very frustrating.
I found my solution by installing Simi Clock Widget, which is pretty customizable and allows you to launch apps by tapping different places on the widget. I took a shot in the dark and linked a tap location on Simi Clock to the stock HTC clock app and it worked! Afterward, the tap from my regular clock started working also.
Good luck! I hope you don't have to reset in the future.
