I have been using the alarm clock on my Inc2 by just tapping on the clock on the main screen and going to the alarm clock. I went to go set it last night, I tapped on the clock, and nothing happened. I can't get to the alarm clock anymore.
Has anyone had this issue before and if so, how do you fix it? This is my only alarm clock, so I need to get this fixed as soon as possible.
Thanks in advance for your help!
