How is the incredible 2? about the same as the original???
Go to Settings - Applications - click on Market then click on remove data and click on force stop. Now go to your drawer menu and launch Market. It should update to the new version automatically.Has anyone who obtained the Incredible 2 having trouble updating the Market? I have reset my phone once already and its still the old Market interface. Checked troubleshooting on the Android Market site and it suggests to go into the Market, then hit HOME and it will update itself, but has not yet.
Also, I cannot locate PDANET in Market...not sure if its related to me being unable to update.
Thanks!
Thanks Electrik Noize! That worked for me.
I am in Kentucky (central) for all of you in Kentucky having problems with the contact phone numbers.
I have/had the 00151 problem as well. I read on another forum about a workaround.
Go to Settings -> Call -> Assisted dialing and change the default "National Number Length" to 7 instead of the default 10
My Dinc2 is set to CDMA mode. I can now call people in my Contact list without it adding 00151.
hope this helps. btw none of the numbers in my contact list include a 1 at the beginning e.g. 1-xxx-xxx-xxxx it's xxx-xxx-xxxx. the one at the beginning seems to throw my phone off.
