1. egborko's Avatar
    why does restarting the phone drain the battery by about 5 percent? Seems crazy!
    05-06-2011 10:54 PM
  2. Sugrat's Avatar
    I don't think it drains it but I think that the battery monitors are not 100% correct at reporting the battery life so after a reboot, you might be closer to the correct power level of the battery.
    05-07-2011 12:34 AM
  3. tack's Avatar
    Reseting drains the battery on many types of phones. My BB used to see major drop from a batter pull or reset.
    05-07-2011 07:38 AM
  4. kf6kmx's Avatar
    When I had my BB storm a batt pull would drop sometimes 20% from where it was before pulling it (not to mention take 10min to boot up!)
    Sent from my Xoom using Tapatalk
    05-07-2011 07:40 AM
