1. AJFSTORM's Avatar
    Sorry if it's a noob question but this is my first phone with WiFi. Does it use whatever is the most robust for the task IOW use it for web browsing rather than the cell connection when available?
    04-29-2010 03:48 PM
  2. Matt_AC's Avatar
    Very summarized answer: When on a Wi-Fi network, your Incredible will have access to the same internet speeds as a PC would on the same Wi-Fi network. When not on a Wi-Fi network, you're restricted to 3G.
    04-29-2010 03:51 PM
  3. nyc_rock's Avatar
    If connected to wifi your phone will use that for anything data related. Once you disconnect it will go back to using cell towers.
    04-29-2010 03:54 PM
  4. AJFSTORM's Avatar
    Okay thanks guys.
    04-29-2010 04:55 PM
  5. dgalanter's Avatar
    They really should learn to route calls thought WiFi for ya. Would be awesome inside basements.
    04-29-2010 05:16 PM
  6. richpjr#AC's Avatar
    Can you use WiFi and 3G at the same time (i.e. talk on the phone while browsing the web)?
    04-29-2010 06:14 PM
  7. bulldogmoe7's Avatar
    one word answer for you "FAST"
    04-29-2010 06:33 PM
  8. dgalanter's Avatar
    Yes. An email came through via WiFi while I was on a call.
    04-29-2010 06:36 PM
