I downloaded this theme for launcher pro, and then my phone froze. I took out the battery and restarted.now when i unlock my lock screen it opens up to a black screen! i can scroll the notification bar but thats it! helpp
if you can scroll the notifacation bar your theme/launcher probably crashed and isn't booting up....what i would recommend is try uninstalling it, or do a factory reset
i've used LP and that is very strange, i've never had that issue happen.
