1. bss's Avatar
    Whenever I add someone to the favorites panel on my DI it just puts them in alphabetical order...is there any way to manually arrange the order of the shortcuts? Or should I just get rid of that widget and just use shortcuts on the main screen?
    04-29-2010 09:52 PM
  2. kmully's Avatar
    Would be interested in knowing about this as well...
    04-29-2010 10:10 PM
  3. homsie's Avatar
    No, there isn't a way to order the entries in the favorites panel. It's always alphabetical order (by first name).
    04-29-2010 10:14 PM
  4. amolchopra's Avatar
    Click and hold the widget for few seconds. Drag it to the "edit" button appearing on the lower left of the phone.
    The phone should show you option to reorder the favorites. Select this option. You will see the list with a reordreing button to the right of each contact. Press and hold the draggable button and move contacts one by one.
    Good luck!
    Gardah likes this.
    09-15-2011 08:11 AM
  5. Dave Richardson's Avatar
    Hi,
    When everyone is talking about the widget, I am not sure what they mean. I really would like to change the order of my favorites. Would appreciate your advice.
    01-15-2015 08:24 AM
  6. maziluflorin84's Avatar
    You cannot change the order of the favorite stations in TuneIn app, but you can do so by accessing your account from the TuneIn website
    11-30-2015 04:18 AM
  7. GeoLaTorre's Avatar
    What I do is put an "A" and a Space in front of the person's name I want in the first position and make the star white in their contact,
    Then I put a "B" and a Space in front of the person's name I want in the second position and make the star white in their contact, etc.. this puts them in the order that I want .
    Hope that helps !
    08-15-2017 04:28 PM
