blunt420
Ok I dnt have a google acct so basically set up a gmail acct? I prob dnt have enuf memory to put google sync on my storm and I think my contacts are on the sdcard
Customized sound profiles. I had one set for work, for example, where everything was silent except for phone calls and appointment reminders, which would vibrate. This was the setting I used when I was sitting at my desk. I haven't found an easy way to replicate this yet, without manually changing notification preferences for different types of messages each time.
Any idea whether Droid or HTC has some kind of program similar to Blackberry's Desktop Manager? How does the phone sync to your Outlook account for calendar/ contacts, etc?
Also, what are some other good sites/ forums to check out? I usually use Crackberry and BBHybrids for the Storm suff. Anything similar?
There are only two things I've noticed myself missing:
The ability to turn the phone off and have it turn itself on at a predetermined time. I used this every night on my BB; I'd set the alarm and then shut the phone off to save the battery.
The only other difficulty I've had is adjusting to the notification light; I'm so used to seeing that little red blinking light, but on the Incredible it's yellow and not as bright, but I'm sure I'll get used to it.
Lastly, I love the alarm clocks on this, especially being able to set multiple alarms as opposed to just one on the BB.
Overall I LOVE this phone, it's so much better than any BlackBerry I've used. Keyboard is excellent too.
What is the best price for the inredible??Is Verizon the only one that has them ??
Are the pictures automaticly saved to the SD card, or do i have to move them? I liked on the BB they were auto saved.
You have to change the storage in the camera's settings.
Start the camera
See the tab on the far left edge of the screen? Swipe it to the right.
New menu opens up.
Bottom button is settings.
Look for "Storage"
