palomosan
I'm gonna try it because my battery life has been poor, I even went as far as removing widgets from the stock scenes and still, so I hope this helps, I'll try it tomorrow and give a report, thanks for the tip.
Also good points! As for bad batteries, thats a different story completely and it does happen. If I had any doubt, I'd bring it in and have it checked. As far as comparing it to the Droid, doesn't it have a larger capacity battery? I'm not sure there, just sounds familiar. They also run different hardware, software, and have different capabilites. Hard to compare battery life. I just meant Andriod phones in general. Hell, even smartphones. With all they can do, battery is gonna be an issue.
Interesting on VZW lady telling you to use a task killer. I know there is a lot of debate on that, and I'm not too concerned with all the arguments, I just do what works for me. I used to have an Eris, and killing tasks helped with that. As my Incredible has much more memory and a much better processor, I haven't even thought about getting a task killer. I'm not ruling it out tho. But I'm off my topic lol. The VZW rep. Brought that up because I'm currently in the process of trying to get both Google and htc's "official(ish) take on the whole "Android/Linux-memory allotment-task killer app-or not" debate. Basically out of curiosity. Intrested to see what they have to say.
Anyone try a Touch Pro2 OEM battery yet?
i unplugged mine at 815am today, by 1pm i was down to 26% battery, i had unchecked the option in the beginning of this thread before unplugging it, sync on, auto brightness, wifi off, and gps off.
the battery went from 38% to 25% within 15 minutes when i was actually watching it.
all i did in that time (~5 hours) was send out about 25 texts and look at 2 websites for about 10 minutes.
my droid would go an entire day (i mean like 10+ hours) doing WAY more than that. i think the battery is defective, as it also overheated on sunday while sitting in a 74F car with the windows down charging.
my normal operating temp hovers around 94F which seems way to high for the phone basically being in stand by.
i've ordered the 1750 seidio battery, if that doesn't help, i'm exchanging the phone for another one, as i'm pretty sure it's defective.
f'ing ANNOYING.
I don't think the batteries are defective! I just dont think its strong enough for the phone! My 3Gs would last all day into the evening, my new incredible was dead by 3pm today after moderate use . I will check the extended batteries out, if no good will have to return. In this day and age an OEM battery should last a full 24hrs.
In this day and age phones do a lot more. Your 3GS didn't have any multi tasking ability. That said, I do agree that the stock batteries should last longer. After a few tweeks mentioned by the OP...my battery life has vastly improved. Pulled it off the charger at 7am today and 2.5 hours later, after some emails and light browsing on the web, I'm at 95%!
alright where are you guys getting these specific readouts about your remaining battery power in terms of a percentage? I can see the "bars" in the "about phone" section that shows 10% increments...but some of you guys are reporting 57%, 3% etc... I'm new to Android...can't find a number that specific on my phone.. ?
