Ok I got a used Incredible from a friend who said the software was funky and it was stuck on the White HTC boot screen, so far I followed these directions but when I press the power button at the end of stage 4 it resets the phone to the HTC splash screen again, I never get the confirm stage 5.
Hard reset the HTC Droid Incredible; Android powered smartphone. This will remove all data from the device and set it to factory defaults.
1. Turn the phone off. If it?s frozen, pull the battery from the device, then replace it.
2. Hold the Volume Down button and press release the Power button.
3. Keep holding Volume Down and wait for the screen with the 3 Android images to appear, and then release it.
4. Press Volume Down to select Clear Storage, and then press the Power button.
5. When prompted, press Volume Up to confirm your selection.
The HTC Droid Incredible will then restart and the hard reset will be complete
I also downloaded a factory RUU but when I run that I am getting Error [170]: USB Connection error, but I installed all the right drivers for it and windows XP and Vista recognizes it.
Whats my next step to get this thing back up and running???
