Save big + get 3 months free! Sign up for ExpressVPN today
FM Radio Question
- Is it just my phone, or is this function useless?
I'm on phone 2 for the same issue and keep having the same problem with the FM radio. Trying out 2 different sets of headphones, I may get 1 or 2 stations with all the rest that should be coming in only being static. Now, if I pull out the jack about half way, I get reception across the board.
I took my original phone into the store and the tech agreed and had the same issue. Static with maybe 1 station playing well..but when the headphones were pulled out half way, more and more stations where able to be listened to.
Anyone else having an issue with the FM radio like this? Are any of yours working flawlessly with the headphone jack all the way plugged in?
Thanks for your help.05-12-2010 11:07 PMLike 0 - Nope, exchanging didnt help the issue one bit. I'm not sure if I should bother sending it back for another one or not...05-13-2010 08:59 AMLike 0
- I've only tried using it once (since I have a BT stereo headset), and I was able to pull in 2 stations clearly. One I was looking for, and a much weaker one that came in by accident (both around 103 on the dial). Since I wasn't looking for anything else, I didn't notice any other issues, but I will check on that tonight and if you don't hear from anybody else I'll let you know what I find out.
Any wired headphones are supposed to work. No headset came with my phone, but it's supposed to use the wire as the antenna. The app will warn you that there's no headset plugged in if you try to start it without one.05-13-2010 09:16 AMLike 0 -
- I found an old headset here, so I tested it (it's an Olympus headset designed for dictation/transcription, but it's got the standard plug).
These are the (11) stations that are tuning in clearly:
90.9, 91.7, 94.1, 94.9, 98.5, 100.3, 101.1, 101.9, 102.7, 105.1, 107.1.
These (5) stations came in static-y, but somewhat listenable:
92.5, 93.3, 97.3, 103.5, 104.3.
I should note that the building I am in has a metal structure that seems purposefully built to block radio waves (we have wifi issues frequently, I cannot tune half of these same stations with my clock radio and analog tuner, and there is a 5' section in my office [where I tested these for you] where I have no cell service, but to either side of this section I have 3 or 4 bars consistently).
I would also like to note that Cincinnati has a lot of crappy radio stations.05-13-2010 10:03 AMLike 0
- Forum
- HTC Android Phones
- More HTC Phones
- Droid Incredible Series
- Verizon Droid Incredible
FM Radio Question
« Incredible music player problems, crash and can't read off sd or internal
Incredible screen timeout issues on car dock. »
