Y key on keyboard does not work???
- My daughters incredible is having an issue where the Y key will not function on the stock keyboard or while using swiftkey x. You have to turn the phone into landscape mode to be able to type a Y. Any idea what could be causing this? Is it possible for a specific portion of the touch screen to not work? No visible damage and phone has the latest OTA update from a couple days ago (had this problem before the OTA so it's not being caused by the latest update.
Thanks for any insight.11-22-2011 03:54 PMLike 0 - My daughters incredible is having an issue where the Y key will not function on the stock keyboard or while using swiftkey x. You have to turn the phone into landscape mode to be able to type a Y. Any idea what could be causing this? Is it possible for a specific portion of the touch screen to not work? No visible damage and phone has the latest OTA update from a couple days ago (had this problem before the OTA so it's not being caused by the latest update.
Thanks for any insight.11-23-2011 10:55 PMLike 0 -
Appreciate any help. Thanks.11-27-2011 04:08 PMLike 0
- Forum
- HTC Android Phones
- More HTC Phones
- Droid Incredible Series
- Verizon Droid Incredible
