Help ! Android Central FC error message whenever I turn on the phone
jasonvancouver
327
17
I usually power down my phone at night and for the last several days, I am getting a Force-Close error message :
Sorry !
The application Android Central (process com.androidcentral.rss) has stopped unexpectedly. Please try again.
FORCE CLOSE
Do I need to just uninstall / reinstall the Android Central Widget ?
thanks!
Cory Streater
9,495
3,428
Try going to settings>manage applications and select the AC app, then do a clear cache. If that doesn't work, I would uninstall/reinstall.
jasonvancouver
327
17
Thanks, Cory. I went to the cache and there is no cache data 0.00B and the 'clear cache' button is gray. I will uninstall and reinstall if see if that does the trick.
thanks !
Jason.
jasonvancouver
327
17
I uninstalled and reinstalled and still getting the FC message when I power-up the phone.
I am not too worried about it. I'll check back later it see if any other information about this.
It seems like a lot of apps. FC on the Incredible. I am just getting into using the apps. Why do they FC so often ? Just curios. It's not a big deal to me.
sermon8r
20
Sorry !
FORCE CLOSE
thanks!
I did a factory reset and fixed it for me
Jan
