Originally Posted by
Cory Streater Try going to settings>manage applications and select the AC app, then do a clear cache. If that doesn't work, I would uninstall/reinstall.
Thanks, Cory. I went to the cache and there is no cache data 0.00B and the 'clear cache' button is gray. I will uninstall and reinstall if see if that does the trick.
thanks !
Jason.
