Save big + get 3 months free! Sign up for ExpressVPN today
kill my battery?
View Poll Results: will this kill my battery?
- Voters
- 19. You may not vote on this poll
- I tend to leave my incredible plugged in while at home or work so when I leave I have a full charge, because I use it constantly and tend to drain it pretty fast. Now I'm wounding if this can kill my battery. I know with laptops your supposed to remove the battery if you have it plugged in 24/7 or else you can kill your battery and it won't hold a charge. Would this be an issue with my incredible?
I'll prolly get Seidio's extended battery when it comes out.05-23-2010 07:01 PMLike 0 - 05-23-2010 08:14 PMLike 0
- If your worried about it, buy the Igo Power Smart Tower. This smart tower detects if a plug in needs power and turns on the plug for you. It checks to see if the appliance needs power (like a cell phone for example) if it does, it turns that plug on. If it doesn't it will turn it off and save power. In your case I would think it would save your battery if your worried about it.
I do not own/use this product so I have no idea if it will work or would damage any thing. Use at your own risk.
"iGo" Power Smart Tower with iGo Green® Technology at iGo, Inc.05-23-2010 10:21 PMLike 0 - Bingo. Although, I would recommend every so often that you run your battery down and then do a full charge just to cycle it. As time passes, your battery meter will become less and less accurate, and by cycling it, this will help calibrate that meter again.05-23-2010 11:22 PMLike 0
- I'm still confused about how the battery works on the Incredible. This morning, I took my phone off of the charger and (phone being on), like many of you, it fell to 94% in about 5-10 minutes and held there. When I got in the car, I turned on my GPS and about halfway to work I plugged it into the car charger so I didn't waste battery too much. Right before I got to work, the light turned green and it hit 100%. I expected it to instantly fall down to 94% like before, but now it's hanging at 100% and I have no idea why.05-24-2010 08:04 AMLike 0
- I'm still confused about how the battery works on the Incredible. This morning, I took my phone off of the charger and (phone being on), like many of you, it fell to 94% in about 5-10 minutes and held there. When I got in the car, I turned on my GPS and about halfway to work I plugged it into the car charger so I didn't waste battery too much. Right before I got to work, the light turned green and it hit 100%. I expected it to instantly fall down to 94% like before, but now it's hanging at 100% and I have no idea why.05-24-2010 08:30 AMLike 0
- Tell us about your charging habits. Do you go to bed at 9:00 withe the phone on the charger? Or do you go a day or two before re-charging (that would be hard to believe, but....)05-24-2010 10:31 AMLike 0
- I usually go to bed at around 11-11:30, and put it on the charger then with the phone still on. I usually take it off the charger at around 7:45am, and the phone decreases by about 6% within minutes.05-24-2010 11:07 AMLike 0
- LiIon batts need to be calibrated every so often, so although you shouldn't do this every time, you should probably cycle the battery every so often to calibrate the accuracy of the battery meter.05-24-2010 12:15 PMLike 0
) My humble opion is based on information received through years of networking with wonderful people like those of us on this forum and several others.
Here's my working theory: like many cellphones (the Samsung Omnia, for example) in order to protect the phone/battery, the DI battery charging system may stop when the battery is fully charged, and then not continue to "top-off" the battery even though it is still plugged in. So, when we plug our phones into the charger and go to bed, it is likely fully charged by, say, 3:00 a.m. If my theory is correct, then the phone receives no more charge until is is unplugged and re-plugged into the charger.
Now, depending upon how much stuff you have going on / automatically updating in the background overnight - this will impact how much battery loss you see shortly after you unplug. The phone has been mildly active (though asleep) after the charging stopped at 3:00a.m.
So, after unplugging you wait a minute or so and if you re-plug your phone into the charger you should eventually get a green light and you then achieve a genuinely full battery.
...my $.0205-24-2010 12:32 PMLike 0 - Keeping li-ion batteries at a voltage of 4.2 is not recommended as it can cause premature corrosion. This is where the recommendation of not keeping them plugged in continually comes from. In some of the newer laptops, vie seen that the charge percentage drops to between 97 and 95% to keep it away from that 4.2v level.
Worse case, if you want to keep it plugged in, go for it. If you lose battery life, I'm sure there will be plenty of cheaper after market batteries available by the time you need a replacement. I also agree with the member that said draining them down all the way is not good as a practice because it isn't. I try to charge mine when it gets down to around 40%, but in the real world, this isn't always possible.05-24-2010 12:34 PMLike 0 - hmm, I'm used to my old phones that I had to completely cycle to make the batteries survive...I was anal about it and knock on wood have never had to buy a new battery for any of my phones before my 2 yr upgrade date. That said I'm seriously considering the extended battery for the inc. but it has me wondering if I should just start keeping an extra usb cord with me at work and keeping it charged while on my desk.05-24-2010 02:01 PMLike 0
- This is just a summary of what I've read over the years. I am not an expect on batteries or even a chemical engineer. This is just what I've read.
Lithium batteries should have a built in circuit to prevent overcharging. In general, Litihium batteries do not like to be deep cycled (and I've read that letting them go completely dead will actually kill the battery's life). However, the meter that reports your "percentage" will become inaccurate if you don't do a rather full discharge every now and then. (The evil fruit company recommends letting the battery go down to 20% or so and then charging fully about once every month to keep the meter accurate.)
Take this with a grain of salt.05-24-2010 02:49 PMLike 0
- Forum
- HTC Android Phones
- More HTC Phones
- Droid Incredible Series
- Verizon Droid Incredible
kill my battery?
