So, After many failed OTA updates to GB, I finally had Verizon walk me through it yesterday. had to brick the phone to factory setting, but the update went ok after that. Got all my apps back, all seem to be working ok.
However, I've noticed that my battery UPTIME and AWAKE time never seem to zero after shut-down and re-boot like they used to. It just keeps going/going/going. I think battery life is ok so far, but I used to be able to monitor my battery by reviewing the up and awake times to make sure nothing was running in the background, really can't do that on a daily basis now. The battery times will reset to zero with a battery pull, but why should I have to do that with GB? Didn't have to with Froyo.
Anyone else experience this, and if so, is there a resolution?
Thanks, Jo
Thanks, Jo
