1. ThirstyTurtle's Avatar
    Does our LED indicator light not have multiple colors? On my Droid I could set it to blink any color for my text messages via Handcent and liked using Blue but on the Incredible I can't seem to get it to do anything other than green...
    Anyone know what's up with that?
    05-24-2010 04:09 PM
  2. rpfarrah's Avatar
    So far just reddish/orange and green. Maybe an app will pop up....
    05-24-2010 04:13 PM
  3. jayhawkfan18's Avatar
    I saw the option to change the color of the LED in the Handcent options, does this NOT work on the Incredible? (sorry, haven't tried it myself yet..)
    05-24-2010 04:16 PM
  4. rpfarrah's Avatar
    Also, FWIW, I've tested the app BLINK. Does not work on the DI.
    05-24-2010 04:22 PM
  5. lcsglvr's Avatar
    Ive tried the handcent and it doesn't change color.
    05-24-2010 05:50 PM
  6. wowpaw's Avatar
    I think its a bicolor LED so you can do red, green, or a mixture of the two.
    05-24-2010 07:01 PM
  7. threepio's Avatar
    In handcent it works for RED. but I use ChompSMS now and it doesnt work for RED
    05-24-2010 07:54 PM
  8. Cole's Avatar
    Any update on this? None of the applications i've tried change the LED color : (
    Pretty big draw back.
    08-04-2010 02:06 PM
