so far, i've let the battery fully drain twice, and have since followed everyone's advice for charging it when its convenient. turn off the wifi and gps when not needed, and you should be ok. the only thing that tends to drain my battery life is downloading tons of apps at once (i came from a bb curve 8330, so i'm going in a bit app crazy!).
Has anyone gotten any information on when the 3500 mAH battery for the incredible is expected to be be out? 130+% more juice sounds so sweeet.
any tips on getting more out of the hts incredible battery life?
