1. slinky317's Avatar
    So, I've recently realized I have become obsessed with the battery level. My phone lasts for almost 30 hours, yet I'm constantly checking to see what the battery level is. I realized I should just stop it, so I deleted all my battery widgets and monitoring apps.
    However, this leaves the green battery meter at the top of the screen. When I see it decrease a little bit, I find myself suddenly trying to time how long it's been off the charger, how it is compared to other days, etc.
    So is there any app I can download that will outright just disable the battery meter, and only have it shown to me when the battery's at like 20% or less? I think it will definitely help my battery obsession.
    I know it's an odd request, but I'm sure some of you can relate.
    06-08-2010 03:27 PM
  2. gspeed's Avatar
    Strange request.
    You know the simple answer is to just not check the battery indicator.
    Anyways I dont know if there is a way to do so without removing the entire notifcation bar, which seems excessive for such a small issue.
    06-08-2010 03:30 PM
  3. slinky317's Avatar
    I know, it's definitely strange. I don't want to remove the whole notification bar, just the battery part of it.
    It's no big deal. I was just wondering if it could help me with my battery-checking addiction.
    06-08-2010 03:42 PM
  4. krelvinaz's Avatar
    Piece of tape would hide it.
    06-08-2010 03:44 PM
  5. Argent's Avatar
    wait for root?
    06-08-2010 03:47 PM
  6. mclarryjr's Avatar
    Once we have root that will be possible but until then you could use a launcher like ADW or Pro and they both have options to remove the entire notification bar.
    Don't worry your not alone I'm always watching my battery and plugging in when I drop below 100%.
    06-08-2010 03:52 PM
  7. SpartanDroid's Avatar
    No you can't remove the battery notification. I believe someone stated in a previous thread that the only way you can remove any of the icons that came installed is by rooting your phone. So I guess we have to wait to root............
    06-08-2010 06:44 PM
