1. scooz16's Avatar
    I know it will fit but I don't have to be worried about the output being to high on that right? It's the factory charger that came with my Dare.
    06-15-2010 05:59 AM
  2. Diabl0's Avatar
    I am using my car charger from my LG Dare. The wall charger makes the Incredible's battery hot, so I stopped using that.
    06-15-2010 06:09 AM
  3. scooz16's Avatar
    here are the specs. Why would it overheat it?
    Input 100-240V ~50/60Hz .2A
    output 5.1V .7A
    06-15-2010 06:25 AM
  4. rpfarrah's Avatar
    I believe they will work. My wife's Q9h charger works, for whatever that's worth.
    06-15-2010 06:38 AM
  5. Diabl0's Avatar
    output 5.1V .7A
    I don't know why it does. You asked. I'm just telling you my experience with it. Try it and see how it works for you.
    06-15-2010 06:40 AM
  6. scooz16's Avatar
    will do and I appreciate the info. Just don't want to harm the phone.
    06-15-2010 07:48 AM
  7. aplittle's Avatar
    I use an LG charger, blackberry charger, I think the only charger I haven't used is the one that came with the phone. I have not had any issues with any of the charges. Hope this helps
    06-15-2010 11:30 AM
  8. jdazzr's Avatar
    i use my Dare charger as well with no problems
    06-15-2010 07:24 PM
  9. anon(28010)'s Avatar
    BB car charger, LG Dare wall charger..It all works..
    06-15-2010 08:33 PM
  10. jdazzr's Avatar
    I did inspect the charger before I used it. And I believe it was weaker than the factory HTC one so I figured it was fine.
    06-16-2010 01:08 AM
