1. Sere81's Avatar
    I installed shapewriter but for some reason it wont let me shapewrite. It is checked under the language and keyboard setting. Any ideas?
    06-19-2010 02:13 PM
  2. roninjoker's Avatar
    Make sure you long press any text input field to get to the option to select input method, then select the keyboard you want.
    Sere81 likes this.
    06-19-2010 02:27 PM
  3. Sere81's Avatar
    Thank you!
    06-19-2010 02:32 PM
